marker licht im Head light assembly of 2011 Ralliart
Alle Infos hier im Forum Mitsubishi Elbetreffen 2024 Thema oder auf der Elbetreffen-Webseite unter Mitsubishi Elbetreffen -Webseite
  • I need some help...the marker lights inside the headlamp assembly are not working..possibly the bulbs are gone...
    what is the best way to remove them on both sides
    these are the amber lights located on the farthest side of the head light assembly....NOT the marker or the turn signal light located on each fender..
    the lights I am speaking off are inside the headlight units...
    thank you...I hear one can remove them without removing the front bumper...
  • Are both light (left and right) not working?
    If this is the case I would guess the cause is not a broken bulb, maybe a fuse or something like that.
    It´s not very likely that both bulps braking at the same time.
    In case the bulp is broken: it´s easy to remove this, just turn the bulp (not sure if left or right direction) and than you casn remove the bulp. It´s the same way like the other bulbs in the headlights.
    I do not remember when I changed my turn signal lights if I removed the big platic cover on top between the headlights, but it´s possible to change the bulbs without removing the cover. It could be a little bit easier.
    I hope this is helping a little bit.
    [font='Times New Roman, Times, Georgia, serif'][size=8]Bilder: Lancer CX3A
    [url='http://www.mitsu-talk.de/wbb3/index.php?page=Board&boardID=51']
